Any interest in doing another IHI by chance![]()
For sure, they're fun to do.:thumb:
Send me a PM if you want to know more.
Yellowchevy
I know this has nothing to do with port and polishing the IHI turbo but I found a solution I figured that if your going to port and polish it may as well get all the new found air to the engine properly. I found out the stock LBZ driver side pipe will fit in place of the crappy 90deg silicone hose and short IC pipe and rid the dreaded brake line/power steering leak rub issue.
Looks real good Russ :thumb:
Was it pretty tight where the uppipes bolt up? I know the IHI it seamed it was opened up Quite a bit and i was wondering how the Garrett compared?
If i had a customer that wanted this done Russ how much would it cost?
Very awesome let us know how it runs :thumb:
Was the dyno with the lly or the ihi turbo? great job btw:thumb:
on the LLY charger....do you happen to know the torque spec on the front half of the compressor as well as the 4 bolts that hold that assembly to the center section? The compressor wheel is torqued to 175-200 in-lbs.
thanks!
