just three bolts???
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
So if i was to remove the three 17mm bolts that hold the turbo down will it move toward the firewall say 2 inches?
Reason being, i need to get the y bridge out.
I cant get to the bottom back bolts and the top back bolt wont come out cuz the compressor housing of the 4094vgt is in the way of extracting the bolt
So if i pull he three bolts that hold the turbo, what else would need to be loosened?
I figured the up pipes and downpipe should be it? Right?
Thanks for the help!
Hot COCOAL
Jun 9, 2012
4,433
Heres the All Season Diesel y bridge, with a little elbow grease(polish), that will replace the stocker
picture.php
Lots more flow, directed toward the runners
picture.php
The two o-rings seem like pretty weak sauce, they were all that was keeping the y bridge elbow in place
picture.php
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
How far do you want to push your engine? I would have spent the money elsewhere
Polaris7x
Dec 25, 2011
406
loves park, ill
unless you have small hands with long ass fingers id sugest doing what your doing, i put my new bridge in when my turbo was in and had a fantastic time doing it to the point where i took a few hour break in between. I have the profab and will be switching over to the all season eventually if i ever tear apart the truck again, atleast you wont have to worry about blowing the stupid tube out anymore
yellowchevy
1,933
93
Louisburg, KS for now
Correct me if I'm wrong but isn't the 4094VGT inter grated into the pedestal just like the stock turbo?
If so you'll have to remove/unbolt the up pipes regardless.
Remove the downpipe, up pipes, oil lines, and water lines; you'll be set then.
Just my thinking being I'm not standing over you engine bay.
Good luck
Yellowchevy
Hot COCOAL
Jun 9, 2012
4,433
Paint-
Yeah, well, i didnt want to buy this right now, but, for some reason the y bridge horn/elbow popped out 2 time in one week, once while data logging boosted launches and w.o.t runs(simulated 1/4), then during a downshift in the street tune, probably cuz big twin cleaned out all the egr and pcv goo that was holding it together:rofl:
Tryin to get to that damn thing is a big bisnotch, rather than screw around with a failing part, i figured replacing it was the best alternative, i already have an egr delete tube with the brace to help prevent this problem, if it weren't for bad luck, I'd have none, and as luck would have it....
I am only pushing 40-42 psi right now and plan to go for more later on, i tow a bunch and play more
Damn what a P.I.T.A!!!!!
Not worth it as a stand alone "upgrade" or "mod" for sure!
To top it all off, notice the connect point, no flange, so my cold pipe needs to get modified, AGAIN, and i just got the damn thing powdercoated too, but, now I'm 3" all the the way to the runners
Hot COCOAL
Jun 9, 2012
4,433
Thanks everyone:hug:
Where is the best place/end, to remove the oil and water lines?
xtremebikr04
Jan 17, 2011
573
Vermont
Ive seen big improvements from swapping out bridges with proper 3 inch intercooler piping to match. I wouldnt call it a waste of time or money. just my $0.02
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
In a fully built truck sure it would net some gains but 500-750 hp is it really needed? No
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Your not going to gain 2" just unbolting the turbo.
I built a custom ground down socket to do my y-bridge bolts and a flexible 1/4" extension. You can't get a ton of torque using the flexible extension but I haven't had it leak yet. Tighten the back lower nuts first, then move to the others. You will actually make the two lower rears tighter once the others are tightened. If you are having trouble keeping the nut in the socket use a piece of tape or some grease in the socket to help hold the nut.
If your hell bent on moving the turbo just take it out. By the time you take everything loose to get it to move, it should be ready to come out...
Harbin_22
3,858
Southern Indiana
My rdl is 100x easier to get in and out with the turbo completely out. I get the front lower ones with a stubby wrench from underneath, in the valley
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
on the back two lower bolts use a 10mm shallow, a universal joint and a extension long enought to reach up outta there to get a ratchet on. put the extention from the drivers side top bolt down behind the bridge to the pass side bolt and vise versa for the drivers side bolt. the holds are slotted but you almost have to have the nuts off to slide the bridge out. when you put them back on i used a magnet and a small screw driver to spin the nut back on one side and put the nut on the pass side before you put the bridge in. and hold your mouth just right lol hope this helps
xtremebikr04
Jan 17, 2011
573
Vermont
Ive seen gains in trucks with under 600 hp. Same tuning before and after on a tune that couldnt clean up the smoke before had all of it cleaned up by the top of second gear after. That in itself made me a believer other than the fact the truck was more responsive and had a noticable gain in power from just the seat of the pants.
catman3126
Jul 24, 2012
2,636
NE Oregon
I saw a big drop in egt's but i did profab manifolds, up pipes down pipe 3" pass side boost tube and a 3" bridge. and a BIG difference in exhaust sounds.
RickDLance
1,276
14
We've had lots of people report gains with our version. Believe it or not most say that the turbo seems to spool quicker and the tires light quicker. :)
993
I use a long wobble extension and short 1/4" drive 10 mm socket to get the lower back bolts. When I put them back in, I use electrical tape to hold the nut into the socket. Don't let the tape wrap around under the flange when you do it, and the socket will pull right off once it starts on the stud. You may have to use a pry bar to move the coolant line around to get on them. For the top back ones, I use a wrench to spin them out. On some trucks (mainly LMMs) the top left bolt won't clear the compressor housing so I take a little saw and cut the head off and spin it out the rest of the way by hand or with a pair of needle nose if it is being stubborn. Then I get a pan head allen bolt that is just a little bit shorter to go back in. I tighten it with a ball end allen wrench. I hope that helps.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
59
belvidere,ill
We have done 3 of these now and 1st off its a very nice piece and you can sell you old bridge afterwards to recoop some money.It makes a noticable deeper tone out the exhaust.
We always take it loose and slide it back,on 1, the turbo was removed to be replaced as it was bad.Good luck.
