If I wanted 1000hp I would run forged pistons, and a great valve train and run high rpm and stay the f**k away from peak torque
^this guy has been making a motor live somehow
Is 366 a 2.6??
bcdeutsch731 is more than track verified as the most powerful and fasted VGT powered truck out there. 9.43@148mph on the tune that dynoed 960hp and it carries the front tires! EMiller and Verlon Southwich both run the 72mm VGT twinned with small injectors and are in the low 11's in crew cab daily driven trucks. I ran mid to high 11's with the 72mm VGT as a single on my stock lbz with 45%inj. Am I missing something here because these are real trucks getting the job done despite what some people think about VGT's capabilities.
DDing 1000hp will cause issues. Keep it around 750ish.![]()
I believe Maxxed Out arguably makes more passes without failure than any other truck out there racing regularly. Big power cones with big demands.
Sent from my DROID RAZR using Tapatalk 2
600hp with no low end torque in the tuning gets squirrelly. I couldn't imagine trying to drive a twinned 1000hp truck around town.
Should I even put the money into it if its just gonna grenade within a year or two? Im sure this combo is gonna make big torque especially if it spools up early in the rpm's. You guys think with tuning, some of the torque could be pulled out down low so she doesnt die?
easier than you think sean...you're used to the 472 like i am! :angel:
Currently have a s475 over my stocker with 40over injectors so I know traction sucks up to about 50-60mph but in 4wd it hooks up great!
Guys break these engines at 750hp if someone is telling you you're going to have to build it once at 1000hp they are giving you false hopes. Sure some last substantially longer than others but these arent LS motors in a 2wd 3500 lb car. If I wanted 1000hp I would run forged pistons, and a great valve train and run high rpm and stay the f**k away from peak torque
100 psi is really good! How fast does it spool? Im assuming really quick being a VGT,Im just curious as to what made the decision to go VGT?
I know this is a different animal but my stock lly had close to 3:1 DP on stock tuning, but this was at lower RPM not at peak is this a case with the bigger VGTs?
anywho its still impressive what you have done:thumb:
Oh and to the OP......IMO you dont run 1000hp on the street, you just break parts and cant keep it straight, 4X4 is even pointless i would break all 4 tires loose
