LB7: does anyone know if i have enough to pull 1000 hp on ppe chip
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
ppe hot +2 must smoke like a PIG!! Till you run out of fuel anyway..
pushing that tuner and no knowledge of diesel performance at all will get you in BIG trouble fast!
Including(but not limited to) bent rods, broke tie rods, burned up cp3 and injectors, broken pistons and on..
BackNBlackTJ
Ahhh, yeah... about that!
Dec 22, 2009
66
Arid-zona
Hmmm, needs more bacon...
:joker:
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Candy, twinkies, kittens, and puppies, and ice cream
Edit. And handcuffs and duck tape and rope and a shovel and large duffel bag
JRODS*LB7
Feb 1, 2012
642
46
SE Massachusetts
Perhaps you could be voted in as PPE Spokesperson. Not doggin on you at all. The best advice is to just chill on doing the addition thing of what the Ford and Dodge guys do: add up all of the advertised "horsepower mods" and get realistic.
Do you want 750 to 1000 HP? There's a lot of difference there. Which do you want? Whichever it is, plan on a short block build. This means at least connecting rods and probably pistons and a cam. To support the cam, new valve springs. To support all of that, a little machine work. When ALL of that is done youre looking at some coin.
To be honest, yes PPE can support 1000hp with PPE stuff alone, but if you are going that way (which doesn't make sense) you have to figure in ALL of the support. You can't win a battle fighting with m-16s alone. Good luck to your endeavor.
I like tacos.
Y not Rambo did?:D
carter_44
May 11, 2010
575
AZ
When did they start making the super badass ALL STOCK 625hp (at the wheels I'm sure) Cummins? I will buy one right now!
