LLY: S472 batmowheel installed!
Ryan T
1,007
50
CA
Im running a billet s472 with stock injectors, and my truck runs way harder than it did with the stock vvt, it was runnin 12.50-60s, injectors and a second cp3 are next... Very fun turbo, Very driveable IMO, keeping in mind i dont tow or haul anything..when it lights hold on !:woott:
2005LLY
Sep 18, 2011
379
Have any videos of like 0-60 or a 40-100? Basically same setup I want except I'm thinking 60%
LWATSON
future trans limpers
Jul 30, 2008
2,587
56
Scotland Neck NC
Go to Youtube and search LWATSON billet s475 its a run from 0-90. I didn't power brake, just stabbed the pedal from a dead stand still. You see a pause at about 2000 rpms, this is when the charger lights, this is also when the tires break loose if its in 2wd.
2005LLY
Sep 18, 2011
379
My damn iPhone won't let me watch it. So you guys are running stock fuel and not having issues with it lighting? I kind of want to just put the charger on and see what it does.
Dirtymaxx03
3,109
Mine surprised the hell out of me the first drive I took it for a spin after I finished the install.
LWATSON
Jul 30, 2008
2,587
56
Scotland Neck NC
The only time I have to do anything different because of the big charger is when I pull out to pass. I drop it in manual so I can downshift to 5th or 4th to keep it from blacking out the road. A truck with a 5 speed would hardly ever be a problem but 6 th gear is too tall to pass with running 50 mph with my charger.
LWATSON
Jul 30, 2008
2,587
56
Scotland Neck NC
I just towed 8-9 k with my S475 friday and could tow in 5th and only had to drop to 4th on a few hills. 14k is probably going to be a little heavy for a big single, doable on occasion with no problems but not good if you tow heavy often
Dirtymaxx03
3,109
I towed about 10k with the cruise at 70 mph and it never downshifted for any hills. It was a little gutless down low unless you really got on the throttle. Overall its not too bad IMO
HDdave
175
Wilmington, NC
Yeah thats the only time I ever noticed anything with my charger.. I don't have the tap shift but I wish I did.. If my converter is locked up doing 50-55 and I need to pass I will just blip the throttle real quick to downshift then I dont black the road out and she spools right up. Hooked to a sled the other day and had a kid come up afterwards and he was asking if I had twins because he couldnt believe how quick my truck spooled. Said the 66mm on his cummins is a laggy pig :rofl:
