Help Cp3 issues?
JRODS*LB7
Feb 1, 2012
642
46
SE Massachusetts
i just installed a lbz cp3 in my lb7 along with a brand new lbz reg. now my truck wont start!Truck ran fine before i took it apart just wasnt building enough rail pressure (example)desired was 23,000 actual 13,000 so i decided to change cp3,my injectors wer done about 12,000 miles ago,i double checked all the connectors i disconnected ,cracked the bleeder on the filt housing bled that!just cranks and cranks and cranks?I was told the cp3 i had bought only had about 30,000 on it? i know the reg is brandnew for sure and is humming when key on! Any suggestions?:confused:
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
keep cranking.....its taken bout 15 minutes of cranking sometimes before they start when you mess with the fuel system. double check your connections
13,862
966
I've never had it take quite 15 minutes, but I have had to crank several 30 second cycles before it will finally fire. How long have you been cranking on it?
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Mine took 2 cycles of ~30 seconds each before it started. Gotta give it time to let all the air out.
Check connections again.
If that doesnt work...Do you have efi live? If so, log what your truck says while cranking. Do you have rail psi? It won't fire until you have 1500 psi or more.
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
If you still have the stock filter/plunger, be sure to pump it 60-80 times then pump it or have someone pump it while you cranking it over and keep pumping it for about 15-20 sec after it fires. I've always had mine start up right away when doing it like this.
60-80 times!?????? :( lol I just crack the screw and turn the lift pump on. But I'm lazy.
Harbin_22
3,858
Southern Indiana
Sorry fuel rail pressure. Have the PIDS desired pressure and actual pressure on. Desired should be 5,000+ and the actual needs to be 1500+ during cranking
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
If you don't see 1500psi while cranking, your truck will not fire the injectors. Thus truck won't start.
You can crack the banjo bolt open on the ficm and see if you have fuel going to the cp3. Just don't crack it to much or fuel will go EVERYWHERE when the lift pump turns on.
JRODS*LB7
Feb 1, 2012
642
46
SE Massachusetts
ok gys i pulled the hose off the cp3 inlet and i got pure fuel no air going to cp3...then i cracked the outlet line barely any fuel coming out...?
