depends, how soon do you have to have it back up and running?
Is it bad if I haven't even tore apart the engine from last season yet?
Only if you don't trust your motor building skills.:thumb: I'm going on season 3 without any major engine work.
No it isnt, always next year...![]()
Your to busy trying to be the King of the Mountain anyway :woott::roflmao:
Got the GoPro, hopefully get some good video..... Hell, if I order a new sled I might not touch the truck or hit the track this season. Never know.
You don't by chance have a part number for those blocks do you Travis? What is the qt coupler for on the feed block?
Those blocks took me a long time to find and are my pride and joy. But for you dave I will send the part number but you have to keep them a secret:hug:
The coupler on the front of the feed block is a pressure tap. We use them all over CAT equipment and I was trying to find a way to be able to bleed air out of the system. I can use one of my pressure gauge lines to bleed air out and also hook a gauge up to keep an eye on pressure![]()
What are those for?
Sent from my PC36100 using Tapatalk
making progress
I have drill for the National Guard, but my brother will hopefully be down to TS with it...
Made it 2 seasons and 70+ hooks on the last build, cracked a piston and the main bearings were pretty beat up. Crank failed mag test between 1&2 rod journal and #2 main journal... Went internal balance with a used stock crank and new forged pistons for last season, just gonna pull pan and check bearings.
How many pulls did you put on the new crank? did you like how it ran compared to an externally balanced motor?
