S464/s480
LWATSON
future trans limpers
Jul 30, 2008
2,587
56
Scotland Neck NC
you sir are correct, I would of had to buy an s366 because I don't have stock turbo, ic pipes, uppipes, etc so I just went with a bigger single instead of buying two turbos..I'm sure I'll be just as happy with it ad I would be with twins:)
You wont be disapointed. Although twins are great for all around use you cant beat the big hit you get when a large single lights. Make sure your pointed straight!
LWATSON
Jul 30, 2008
2,587
56
Scotland Neck NC
I like it allot, I was afraid it was going to be a laggy pig, but its not. The only issue you may have will be towing. I have a trans tune with higher shiftpoints that works really well and makes towing light to medium loads with this charger work. Towing heavy is easily done but at much higher RPM's. As far as daily driving unloaded its awesome, not laggy at all. The trans tune I have makes my trans down shift with less throttle input so If I'm cruising at 55-60mph and need to pass I dont have to stab the throttle to get it to go. It downshifts smoothly and pulls fine.
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
sounds awesome! I remember that thread..I was talked out of the 75mm and into a 72mm just to stay on top of the charger and I thought long and hard about it and wanted to use more of the chargers potential on a stock engine..in MO there are some pretty good hills down south so I think it's a good choice..I will definitely post how it is whenever I get it back!
kivetts04dmax
May 20, 2010
742
It's a billet wheel, I'm not a firm believer in the batmo wheels yet..I just don't see a big enough improvement in them and I can switch wheels on a regular BW rather than buying a whole new charger..I think I'll be just as happy
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
It's fine for the small charger... We just rolled a 1013 on an S466/S480 setup today with the gate set at 65psi.
And no JNeal's setup is not on nitrous. It's a stock motor.. He won't let me turn the wick up. The vid is on youtube.
kivetts04dmax
May 20, 2010
742
I'm a little confused Brayden..JNeal has a 466/480 now and hit 1013hp on a stock engine? I'll look up the video on YouTube.
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
i pulled a triple take 1000+hp on a stock Dmax i about shit myself... Was ready to jump in truck and head to you Brayden lol.
