Fuel Cooler
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
How important is the fuel cooler?
I am thinking of removing mine when I install my FASS. I understand it helps cool the fuel that is returning off the motor and of course cooler fuel is better for performance. However neither Ford or Dodge have one.
Am I missing something?
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Wow 195˚ but you are also in a hotter climate then me.
Still kind of interesting that there is that much fuel being pushed back into the tank.
BHoward6.6
West Coast
Feb 9, 2011
274
Huntington Beach, CA
In all fairness the 195* fuel temp was typically seen at low OAT's (50*80*). Mostly because I was pulling my 5th wheel from sea level to 4000'.
IIRC fuel temp's are around 140* while emty at highway speeds.
I would leave the fuel cooler.
quentomania
Feb 3, 2009
47
Should be a more efficient burn with cool fuel. Big trucks used to have warm returns and they pulled a little better when you just fueled up imo. These new 550 cummins have fuel coolers too.
Mike L.
Got Sheep?
15,681
Fullerton CA
I have seen my fuel temp hit 195*.
You are losing power at those temps. 75F is the optimum fuel temp according to Cummins. The problem is, it is difficult to to even get it to ambient temps in the summer or under a pulling a big load. Dual fuelers will also raise temps past 175F. When the temps get close to 200F and above, the ECM pulls power back.
There was a thread a few years ago at DP where the dealer installed a big tank and didn't have enough room for the cooler so they left it off. He was towed back a few days later with a fuel boiling issue under load. The dealer reinstalled cooler and solved the problem.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
I have seen trucks with fuel temps in the 230s, running a truck low on fuel seems to increas temps especially when towing in warm weather!
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Most of the pulling trucks don't have a fuel cooler. Do you think it would be worth while running my return through my ice/water box then. I only have a 5 gallon fuel cell so I'm guessing yes.
Mike L.
Got Sheep?
15,681
Fullerton CA
The fuel in our trucks is mainly cooled by the fuel in the tank and not the cooler. The lower the fuel level in the tank, the hotter the fuel gets. I found this out with a infra red camera.
My old buddy LosLobos in Oregon tested this with his camera and follewd the fuel back to the tank. The camera showed Red ( hot ) to the cooler and Red out of the cooler and Gray ( cool ) when the return fuel hit the tank.
We then installed my fuel cooler and the fuel showed Red to the cooler and Gray when it left the cooler.
It was a very interesting study.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
So you found that the stock cooler does nothing. However your cooler does the job.
One of the reasons I bring this up is my truck gets drove maybe 5000 miles a year and will be more on the lines of 3000 miles after I finish my motor build. I just looked at the FASS instructions and saw I needed to remove it to hook everything up so I figured maybe I'll just delete it.
Texas Chevy
1,103
Vista, Ca
since fuel temps effects power does it also effect mileage?
