AirDog and Cat 1R0751 2 micron absolute filter
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
41
Houston, TX
You can always go to the hardware store and get a brass shutoff valve and splice it into the fuel line between the tank and the pump. I had to shorten my AD lines anyway so I figured why not just put that valve in place of the splice? Makes changing filters so much cleaner.:thumb:
Good idea too! You can also screw out the qd fitting on the pump manifold and use a male x female npt ballvalve if you don't want to cut the lines
Sent from my ADR6400L using Tapatalk
bartman432
Nov 4, 2011
242
Coker, thanks for this write up. Just picked up my CAT filter for only $18.00. I am going to delete the factory filter head unit as well. If any of you are in the San Bernardino/Riverside area, I got my filters from Johnson CAT 800 E. La Cadena Drive, Riverside, CA 92507. (951) 686-4560.
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
I live in oceanside and have been looking for a place that was close
coker6303
Aug 6, 2009
2,484
41
Houston, TX
i got mine direct at the local CAT shop
If they will ship cheap, ill buy at least a case of filters (should be 6 or 8 filters) at the $13 each!! Hook a bro up
08 LMM Chevy CCSB
Relentless Diesel trans
JoshH EfiLive tuning
554hp 1014ft-lbs 7/30/11
bartman432
Nov 4, 2011
242
Coker, I just installed mine and didn't have to grind the edges at all. On the bracket that holds the AirDog assembly, it has space for it to be positioned. I did have to remove those two little tabs and that was it. For the fuel line coming in, I just clamped it and no fuel leakage during the whole ordeal. For anybody else who doesn't want to grind theirs, just loosen the bracket bolts and position the AirDog assembly accordingly. Again, thanks for this write up Coker. My injectors are thanking you. :D
Timmay208
FNG
Jul 22, 2011
154
UT
im sure shipping would bring it back up to normal price, whats cheapest you have got them for? I guess if your getting them at 18 each it would save you 15-20 bucks buying 6-8
bartman432
Nov 4, 2011
242
Anybody know if the CAT fuel/water separator filter will work/fit in the factory AirDog position?
coker6303
Aug 6, 2009
2,484
41
Houston, TX
$21 was the last price here at our cat dealer
08 LMM Chevy CCSB
coker6303
Aug 6, 2009
2,484
41
Houston, TX
All the cat water seperater filters I have found have a 1" inlet and will not fit the airdog
08 LMM Chevy CCSB
coker6303
Aug 6, 2009
2,484
41
Houston, TX
That's awesome!!!! Everyone should try that first and only grind if necessary.
08 LMM Chevy CCSB
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
And pass up a perfectly good opportunity to use a power tool?! I hear that's the first step towards communism...:roflmao:
coker6303
Aug 6, 2009
2,484
41
Houston, TX
Good point!! We should start every job by grinding our initials in the part we are working on. Kinda like marking territory!
08 LMM Chevy CCSB
Timmay208
FNG
Jul 22, 2011
154
UT
crazy how theres that much difference in price, if you wanted a box of them i could probably get them and ship them for you
bartman432
Nov 4, 2011
242
Coker this has been a great post. Until now, I never knew the difference between nominal & absolute filters. On the CAT website, it shows the difference in micron sizes. A human hair is 80 microns, damage to fuel systems can occur in the 5-10 micron level, and the CAT filters down to the 2 micron level. Since my truck is out of warranty, I'm trying to do all I can to keep the injectors clean.
