LLY: bad turbo?
05greendmax
dyno and drag numberssoon
Dec 26, 2009
435
ohio
ok i started my truck and high idle cicked on and my truck just started hazeing blue smoke
i am think my turbo seal is shot
i am useing oil and i was wonder if my thinking was correct blue smoke =turbo seal bad it haze at idle ane at all rpms
is it cheaper to just rebuild stocker or if it costs about the same to get a aftermarket i dont need super big turbo one that is dd friendly and can tow with low egts
616samuel
Apr 26, 2011
178
Rockford, Michigan
that doesn't sound like your turbo is shot? my '05 will haze a good amount in the winter in elevated idle mode.
are there funky noises when you drive it?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
The best things to check for if the turbo oil seals are shot would be to pull the down pipe loose and check for oil , as well as the IC tube on the drivers side .
jaredlly
Oct 20, 2011
i had some wat a problem like that my pvc was bad and is was just suckin in alot of oil vapers i rerouted the pcv problem was solved then
05greendmax
Dec 26, 2009
435
ohio
i pulled off the i c tube and i could have filled a dixie cup full of oil i think sheis shot shot and on high idle its a heavy haze of blue so its leaning towards turbo more info welcome
