Ethan check at the CAT in Boonville and see if they have any..I have Evan checking, his dad Mark is a manager there..
There's also Fabic CAT in CoMo
Lol, hopefully u are joking and someone didn't do this to you!
Suger doesn't dissolve in gas or diesel, filters will catch it no problem but choke up quickly.
Sent from my ADR6400L using Tapatalk
So will taking out the tabs effect the performance of the unit or will it just not filter out as much air?
I wonder same thing
We had a tractor get sugared before and it muffed up the usual damage, injector pump, lines and injectors, and once ya get it done to ya once you always worry about it, an airdog was the first thing I did to my dodge I had before my chevy because of it, and I now have one on my chevy, and I just always wondered if it was truly enough protection
I've already talked to someone about making an adapter for these to eleminate modifying anything..just screw the adapter on then the CAT filter, just like on the stock filter housing but with the AD threads..
Just did this..... Should have disconnected Quick Disconnect from tank to AD, Siphoned fuel all over me.
av8or
josh, did a little research and came up with the 1R-0770 being a radial fuel water seperator from cat with a 98% efficiency at 10micron but it has a 1"-14 thread which puts it with he same mount as the 1R0749 2 micron filter. Quite a bit larger than the airdog...
here are a few good pics and the dimensional information too:
http://coralparts.en.alibaba.com/pr..._filter_FS19820_Donaldson_filter_P550626.html
i'm still digging!! i'll let you know what else I find.
Hey I just happened to run across a filter that is interchangle with the 1r-0750 that if a fuel filter/water seperator but I dont know what it filters down to. The part# 175-2949. I hope this is helpful in your search, please let me know.
Lol, I clamped the lines off so leakage was minimal
what did you clamp the lines with???
