What is a "stock" Duramax ?
What mods you think SHOULD be allowed for a truck to still be considered "stock"
  • Total voters
    78
Micheal Tomac
been pulling forever
Aug 12, 2008
273
MI
For Dragracing what is a "stock" Duramax truck?
I think almost everyone agrees that a tune, lift pump, transmission upgrades, intake/filter and exhaust mods are ok. But the following items seem to be in question when considering; What is a "stock" Duramax truck.
In the poll below, vote for what mods you think SHOULD be allowed for a truck to still be considered "stock".
1. Turbo (not counting waste gate mods or wg replacement)
2. CP3 pump (not counting LBZ & LMM regulator & CP3 replacement on an LB7 & LLY)
3. Injectors (not couting stock remanufactured injectors)
4. Tires - slicks & cheater slicks (not counting proxes & other street tires)
5. Manifolds & up-pipes (not counting LML manifold)
6. Fans - electric fans
7. Intercooler & piping (not counting EGR delete)
8. EGR delete / Y-bridge replacement
9. Turbo inlet, mouth piece, elbow
10. Down pipe
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Depends on the context of the word "stock". if youre talking about a truck pull stock class then it means stock motor and turbo with things like an intake and tuner. What exactly are you referring to?
***EDIT*** Sorry poll wasnt up when i posted lol
Micheal Tomac
Aug 12, 2008
273
MI
I ran out of time to add a poll to this thead so I edited the thread and put the poll options in the thread.
Any help mods on adding the poll?
05chevy
1,086
I think stock turbo, injectors, turbo. Any bolt on is fine say manifolds, intake, e-fans, intercooler, 3" ic tubes, 3" y bridge, fpr is debatable.
Micheal Tomac
Aug 12, 2008
273
MI
I think all parts from newer model engines & trucks should be allowed on the older models as replacement parts. Especially when some of the newer parts are cheaper than the older ones.
Mike_S
OOPS!
Nov 18, 2009
803
Idaho
i would say any parts available on a stock engine of the same designation, ie "duramax". Any parts available from the factory, as well as any tuning that you would like to run with the stock fuel system. JMHO.
3,421
I dont know whether to say thanks or not for this thread as it could start a war. Tried doing it once before and it got nowhere but a big argument. I guess someone had to start this discussion here, and better to have a respected DMax racer/puller like Michael do it than a nobody like me. Im flat tired of the BS myself.
I tried to pattern my truck off what mods the Spruill's did years ago as nobody EVER questioned their run's validity, and I respected that they tried to do things above-board. Anyway, since I have more than a vested interest in this list I may as well put my .02 worth in. Take it for what its worth.
Mods that shouldn't be allowed are things that make the truck unsuitable for the street or take the truck away from its other possible jobs (towing, hauling, etc).
That will drop the guys who are running their trucks as "race only" vehicles that might see the street only for a few miles in a rare instance and would not be used to pull a trailer or haul a load..
1) I agree with the turbo. It has to be untouched and meant for the model engine its on. Its the basic piece that all this discussion revolves around. NO "stock-appearing" turbos. No twins.
2) Your CP3 choice does not address modded regulators and suction pumps (bag of parts). Are you including those in the LBZ regulator exception? I agree, no fully modded pumps like Floor It or Wicked.
3) Injectors are either way with me. I believe that the single stock CP3 (even an LBZ one) will not hold up to high pulse with larger injectors, so it kind of evens out in the end.
4) Drag radials are borderline to me, since they dont allow the truck to be used for towing/hauling, but they are still a DOT type tire. Slicks are definitely out.
5) Yes to manifolds and uppipes, as they have become common upgrades for all incarnations of Dmax.
6) Due to the O/H potential, I dont know of anyone running JUST electric fans on their DD truck, let alone anybody silly enough to tow a trailer with just that setup (is someone that nuts?), so those shouldnt be included. Plus, the parasitic draw from the fan does count for something.
7) I voted ONLY for the piping part of the intercooler choice. Many LLY/LBZ guys have swapped their IC pipes out, but I do not believe intercoolers should be part of this discussion. A stock truck shouldnt need one, and for the cost, they are not a reasonable mod.
8) EGR should never have been installed on these engines in the first place. You want to delete it? More power to you. No opinion on Y bridges.
9) LBZ mouthpieces on LLY turbos are common swaps, and intake horn mods and wastegate mods are common for LB7s. Downpipes are available to all models, too.
To add...
a) Heads have to be stock or stock replacement. No porting. No oversized valves. Not sure about springs or pushrods. Replacing LB7 heads with LLY or LBZ ok.
b) Stock cam.
c) Stock waterpump and belt routing. No electric pumps.
d) As for suspension, shocks can be adjustable racing type as long as they are still compatible on the street and bolted in stock locations. This includes QA1 and Rancho. This eliminates trick setups like Trent's both-behind-the-axle setup, though. Springs can have leaves removed or 1/2ton springs installed. All common front suspension improvements (sleeves, braces, centerlinks) allowed.
e) Weight reduction is allowed unless it interferes with the vehicle safety or driveability. Id like to see it where guys have to keep their hoods and front bumpers on though. Again, could you run it on the street like that? I saw those pics of the 50K race and thought the guy stripping his truck to the frame in order to win should have been disqualified.
Removing seats, rear bumpers, etc ok.
f) Vehicle should be a production GM truck (2500hd or 3500) that had a Duramax option. No 1/2 tons, no shortened 3/4-1 ton trucks, no cars. The only exception would be putting Dmax's in 3/4 ton Suburbans similar to what TDIGuy is doing, as that comes out as a "factory" install.
g) Added safety equipment should be part of the discussion, shouldnt it? Driveshaft loops at a minimum, both for front and rear driveshafts. They are easy enough to fabricate or buy from vendors, and are just smart insurance.
I think that covers my opinions.
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
Madras, OR, Pahrump NV
I dont know whether to say thanks or not for this thread. Tried doing it once before and it got nowhere. I guess someone had to start this discussion here, and better to have a respected DMax racer/puller like Michael do it than a nobody like me. Im flat tired of the BS myself. I tried to pattern my truck off what mods the Spruill's did years ago as nobody ever questioned their run's validity EVER, and I respected that they tried to do things above-board.
Anyway, since I have a vested interest in this list I may as well put my .02 worth in. Take it for what its worth.
I figure the only mods that shouldnt be allowed are things that make the truck unsuitable for the street or take the truck away from its other possible jobs (towing, hauling, etc).
That will drop the guys who are running their trucks as "race only" vehicles that might see the street only for a few miles in a rare instance.
Not sure that is a valid criteria, my truck is fully modded and I just drove it to Topeka and back, (3400 miles) and raced it as well. Would take about an hour to put the rear bumber and tow hitch back on it if I wanted to tow with it.
Don't agree with this statement either, that's all I run is electric fans and I venture to guess they do as good or better job then the stock fan did. Stock fan will pull about 25 hp or so I've been told, agree it they shouldn't be allowed on a, "stock" truck for the purpose of the list.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
IMOP its open season for anything but turbo and CP3 , makes it funner and give guys the fuel to get real creative and really push the limits.
3,421
That is more than valid, Ken. You simply change a tune in yours to drive it. My truck is also simply an hour of work and its back to DD status. The only difference between our two vehicles is that you built the motor and run 10s and I didnt and dont.
The concern is there are people who are building purpose-only trucks just to get on this list. That isnt right. The truck has to be able to still see normal duty as a "truck".
This isnt the Top50 list where anything goes.
As for the fan comment, I want to see data from someone pulling a TT with electrics over the stock fan. Driving empty electric fans may work, but everything Ive read says in a towing situation they wont.
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
That is more than valid, Ken. You simply change a tune in yours to drive it. My truck is also simply an hour of work and its back to DD status, too. Only diff between ours is that you built the motor and run 10s and I dont.
As for the fan comment, I want to see data from someone pulling a TT with electrics over the stock fan. Driving empty they may work, but everything Ive read says in a towing situation they wont.
I see your point, guess I can't see why anyone would build a race only stock truck. I raced with the same tune I drive it daily with. Happens to really fix nicely in the 11.90 class.;)
sweetdiesel
That's better
Aug 6, 2006
10,390
53
Thailand
X2 Im so glad i dont try to be on this list:spit: Its always :argue:
Tom, FWIW Brandon Turbotug has been running electric fans and lives in Arizona and tows his trailer all the time. Just sayin:hug:And what does a elec water pump do for HP? I never added mine to pick up horse power
Also lb7 injectors are bigger than LLY.....LB7s shouldnt be allowed:D
And who cares how much weight you pull? Shocks you should be able to run coil overs in the front if ya want too IMO
I dunno this just seems like to much arguing to me. Im with trent
I agree with the added exception of injectors.
Stock fuel, stock turbo, stock internals. Everything else fill your boots.
3,421
You wouldnt believe how tired of it I am. I am more partial to the idea of stock turbo, CP3 and anything else goes than anything else.
