trans upgrade
jmax33
Aug 5, 2011
57
what kind of trans upgrades do i need, looking to take my truck to the 550-600 hp range
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Full build with a good converter. Don't skimp here if u want it to last. Always plan for more hp later cause it never stops. Then do the Pump rub fix. And if u are goin to play hard often, t-case brace and a good trans cooler. Mine and a few buddies are at the level u are talkin about and I'm goin higher in a few weeks when I do my twins, injectors, ect. The trans gets warmer quicker. That's for sure. What are u planning on doin? New turbos? Bigger single? Nitrous?
jmax33
Aug 5, 2011
57
dont really know what mods i want to do yet, just want to make sure the alli can handle it first, dont really want to get over the 600hp mark, for now!
Mike L.
Got Sheep?
15,681
Fullerton CA
Find a good builder and ask him. Don't go cheap and don't buy discount parts and then take them to your builder.
bean
Feb 5, 2011
66
Norwalk
To the OP im sure mikes stage 4 build will be more than enough and it will hold the power you want!
jon5212
Oct 13, 2010
119
I hear the same thing. What options do you have for us zf6 guys? How much hp will the stock trans with good aftermarket DD clutch hold?
From what I've seen the stock ZF-6 are holding trucks over 800 RWHP, just need a good clutch. I think guys were seeing input/output shaft failures above the 800 RWHP mark.
arneson
Aug 14, 2011
2,133
for the pump rub fix it keeps the fins from eating thru the case. U get a bushing to go on the back side between the case. I believe the factory fixed 08+ trucks. They have a different case iirc.
