Piston Bowls
minisub
6-5/6-6;Whatever It Takes
Sep 11, 2006
474
Cleveland, OH
Is this just an LLY issue? My LBZ has never acted right. With the stock charger we had a time getting the boost consistant and now with the new charger its lower on boost than other LBZ's with the same charger and tuning.
Check out Finger's Leaking Intercoolers thread. No one there yet has reported issues with an LBZ, but I am going to check mine...
Fingers
Village Idiot
1,735
142
White Oak, PA
Seems my pressure monitor setup needs some updating. Hope to have it on the truck later in the week.
FWIW, two people have committed to trying this new bowl design in their builds. One will have valve reliefs and low comp and the other will not have valve reliefs.
I've been driving the max effort tune around for a while now. When the turbo lights, she is scary. So far, so good.
Yes Dale Jon has had it tester out for a few years now
Your the official Fingers spokesposter now??
Well aware of the tester. Wasn't sure if this was what he was talking about. Could have been drive pressure too you know.
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
What would this thread have to do with monitoring drive pressure?
Not sure. Just asking maybe for those that don't know about all of the awesome stuff Fingers has done in the past with these engines.........
Fingers
Village Idiot
1,735
142
White Oak, PA
I've always tried to call it a Chamber Pressure Monitor. (CPM) But I slip up sometimes.
FWIW, I hooked up a Dual Needle boost/drive pressure gauge last week for the Dyno session. Very cool.
Fingers
Village Idiot
1,735
142
White Oak, PA
It is a hewitt and is available through Kennedy Diesel. It is not on the online store pages last I looked. You will have to call.
Fingers
Village Idiot
1,735
142
White Oak, PA
Just received a box of blanks to carve for someone else. These will be without valve reliefs. 17:1 compression ratio.
Fingers
Village Idiot
1,735
142
White Oak, PA
Oval only 17:1 piston.
attachment.php
B1 596
Dmax rods cost how much..
Apr 30, 2010
52
Hudson N.H.
So can the blanks be ordered without the rod pins drilled so the pins can be moved up for stroker use....:thumb:
Fingers
Village Idiot
1,735
142
White Oak, PA
Or get uncut stroker pistons and cut in the bowls.
I don't think there is enough real estate to move the pin hole north enough on a cast piston. I haven't really looked though. I currently don't have access to the equipment to finish the hole as well as they are from the factory.
schulte
Jul 31, 2010
449
These will be installed in a fully built motor in (hopefully) the next 2 weeks that should be reliably in the 900-1000rwhp range... See how long they last!
Sent from my ****ing blackberry
Awesome!!:thumb:
Fingers
Village Idiot
1,735
142
White Oak, PA
For all intents, my truck runs just like any other stock motor running stock compression with a bigger turbo and 100 over injectors. I am hopeful that others will chime in eventually with their experiences. I am, after all, biased. ;)
