LB7: Safe lb7 egts?
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
i hit 1200 towing with twins today it was a steep hill but i was only pullin 3-3500lbs and i wasnt easy on that hill no one was keepin up with me lol but i try not to get over that
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
Hagerstown MD
Ok, I raced a crotch rocket to 130mph the other day and it hit 1800 twice but only for a second before I let off. I'm thinking its time for water meth.
JustinD
Plow Truck
Nov 21, 2008
2,067
Tiverton Rhode Island
Water meth didn't help my EGT's too much maybe 100* maybe if you used straight water it might help more???? Mine goes 1700-1800 with my race tune. A bigger charger is the ticket, I been saving my pennies hopefully I'll find a "deal"
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
A lot of times the bigger chargers don't reduce EGTs as advertised either from what I have seen and heard on here.
Especially when you add more fuel to compensate for the new found air.:woott:
8,056
1200 is a safe constant temp. the higher the temp from there, the shorter amount of time the turbo/manifolds can take that heat. I pegged a 1600* egt gauge every time i raced before i put the twins on, this was in 1/4 mile increments though. but when ever i towed up a hill i never let the egts get over 1250 for very long, only for a spurt (ie: passing some one) and always ran a 90hp or lower tune. any more than that and EGTs couldnt be kept in check while towing. Personally, i think the IHIs on our trucks are pretty damn tough if the boost is kept in check.
Mike_S
OOPS!
Nov 18, 2009
803
Idaho
I have always been told that 1350 sustained is safe. I wouldn't worry as much about the turbo of manifolds as i would about the piston/cylinders/heads. that is where your expensive damage is going to occure. that being said, i pegged a 1600 degree guage many times for short bursts when I still ran my IHI turbo, and got lucky and only ever damaged turbos, cylinders and pistons still looked good when I rebuilt after headgaskets let go. but i wouldnt feel too bad running 1200 all day long with the stock turbo as long as the coolant temp stayed in check.
hondarider552
Getting faster
May 28, 2008
10,627
35
Arizona
I dont ever see above 1100* :woott:
I will be going back to stock injectors after the currect set takes a crap though.
wdino73
735
57
Versailles, Ky
If I'm not mistaken Aluminum melts at 1700* so a spike won't kill u but substained will, got the piston to prove it...:thumb::thumb:
dieseldan723
Still learning.....
Jun 16, 2010
61
Good info guys, but I have one question. WHERE are you measuring these temps? PRE-turbo is my guess but I wanted to verify.
Thanks.
