Anthonys block is half filled and it runs awesome for DD
Should have biggest effect on oil temp,,he should monitor it... Jmo
I would certainly 1/2 fill the block, especially if you plan on running big power and not towing with it. Along with a girdle it will help keep the crank from walking around. We had one filled and one not for Max'd Out. Guess which one cracked and also took out the crank? Filled one still looks good.:thumb:
Thanks for sharing Ken
X2... Is there A thread some were on what type of cement to use and what consistency works best? I guess if I go out to the shop and look at the block it should be pretty self explanatory on what part to fill?![]()
