Your not gonna do it on our tracks here in missouri, plain and simple, better do gears or be ready to unlock. Even if you do gears keep your finger on the button just to be ready.:thumb:
What size fuel lines are you putting in to get into the 850 park? Seems like stock won't make it happen with a nice pump. I've never heard where you go bigger after what HP level on a 24v.quit a few,, to hold and get a good hook in fourth on a tight track with stock gears think >850 IMHO
You should become a fan
I got question, I was thinking about the other day, for some of you expert pullers
Your best guess, about how much hp would you need to hang 4th gear with stock gears, and 33/12.50 STS's (no duals) without unlocking the converter on a hard pulling track???
I know there are a ton of variable to factors in but what is your best guess??
Thanks
So then why don't you unlock?? I never heard once in your vids where you unlocked even when you snuffed the charger
They aren't running stock gears.![]()
I realize that, but he acted like unlocking the converter was the only way to go, yet never unlocked his when powering out. It just seems like you loose everything through the converter once it's unlocked, also seems like you break traction once you unlock it.
Try running 900hp with stock gears and let the motor drag down in the rpm and not unlock the converter and see how many rear ends you go through in a season.
Unlocking is for the last couple inches when your truck would have normally fallen off the charger.
We never had a unlock switch that worked.
900+ at the wheels and twins and you will never have to unlock it, no matter how big of a terd sled it is or how hard the track is....![]()
Exactly what I was thinking and why I asked the question. If it does take that much power I think the whole truck would be torn to shit every pull.
Travis from the vids I watched of you pulling you lug your truck way down sometimes and don't unlock(I know your running 4.56), do you break very often?
So do you unlock at 3400 or do you let off?? I knew u were turning some high RPM trying to keep the bottom end alive. If you don't mind me asking what RPM are you turning going down the track?
Bens (duratothemax) works awesome, the unlock/lock version also works awesome for locking the highstall converters that dont want to lock all the time. I was having problems with my converter locking mid track, now it locks as soon as i hit the button every time, and the unlock works without limping the trans too...
