LBZ FPR in lb7/lly
S Phinney
4,008
Quncy, Fl
For the truck to achieve 180 mpa the tune has to be written for that. The pressure tables will have to account for the desired pressure at a given mm3.
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
Correct, and I think he asked the follow up question with the 26k rail pressure, could be wrong tho.
I bet you can hit 26k with the lb7 regulator, I havent tried it yet tho. And some people have had the rail pressure safety valve, like a rail pressure blow off valve, open at 24500, some 25000+, we dont have to "shim" our valves so they hold rail pressure
my blow of valve is plugged and i couldnt hit 26k for the life of me. I have a modded lbz in it now and have no trouble at all.
Bryce418
Still slow
Oct 5, 2009
611
I run tunes that make 190mpa with a stock lb7 regulator.
I also think that a lbz unit would probably be easier to maintain that with 3000+us tunes.
nmband13
53
Sioux Falls SD
I held 190 mpa with a 3250pw tune with the lbz regulator but now with the nozzles can't even hold a 2200 pw above 20ksi so need a bigger pump now :D
Thats like a 3150pw with stock nozzles(if you do the math with 45% over's), sounds like you need a bigger pump or yours is worn out from all that 190mpa you demanding
rcr1978
793
Spring Creek, NV
I need to fix my previous post, I was looking back through my logs and on my tune I was asking for 175mpa and was peaking at 183mpa on a let off or shift spike so it may read higher just thought that it was all it would read cause I only have my dashboard set to 180mpa :eek: :D I know the sensor scaling goes to 200mpa will it actualy read that high? Not sure I want to push my LB7's fuel system much higher than I already am also not sure how much pressure would hurt the injectors so I will stop where I'm at. :D
S Phinney
4,008
Quncy, Fl
The harder you push the injectors the sooner they will wear out. So keeping them 26k and under and preferably 23k and under will help them live a longer life.
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
With a stock LBZ regulator in my LLY pump on a 3300pw tune my truck would touch 25k then drop back down to around 22k
