Dsp5 not populating..update issue??
bluessmax
Tabasco Injected!
Nov 4, 2010
1,154
Lake Charles, la
I have run/made scripts for the lbz/lmm multiple times...well i dont know if it is coincidence or if a update issue, but as i have always done i upgrade the stock file to dsp5, compare to the dsp5 i already made,,create script, then i run that script over the stock(dsp5) file...normally it populates fields 1-4 as does the base tune... however, i'm having a issue. It is only populating fields 1 & 2 along with the base tune and leaving 3 & 4 unpopulated.. i have not had this happen before can someone chime in maybe? When i compare the differences it is not comparing dsp 3 & 4...can someone maybe chime in why? Thanks!:thumb:
There was an issue MONTHS ago (maybe 8-12 months ago) where there was an issue in 1 DSP OS.
I don't remember the exact details other than either a couple of tunes were not populated or they were populated with the same data (it may of been 1 and 3 were the same and 2 and 4 were the same). I can check that out later today and get back to you.
If it is/was that issue it was fixed with a software update. Can you please make sure you are running current versions of both V7 and V8 software from here http://www.efilive.com/index.php?option=com_content&view=article&id=48&Itemid=133
Cheers
Cindy
bluessmax
Tabasco Injected!
Nov 4, 2010
1,154
Lake Charles, la
Hey Cindy, yes I'm running the latest release...joecar had verified this on another issue I was having. I assume I'm just the guy with bad luck!! Would you like for me to send you the file I'm trying to do this with? Thanks!
-Kory
Kory, sorry it's taken so long to get back to you. We have had a couple of issues today with the current build of software.
I'm about to make a post, but if your running build 139 and your certain that nothing else has changed and you've checked all the obvious, I'm going to take a stab in the dark that our LLY failed flash issue extends to cover scripting.
My advice to you given it's only 2 hours and 30 mins until Christmas day in my time zone is to downgrade your software to build 133 - check my new thread for the link and try again.
Merry Christmas
Cheers
Cindy
bluessmax
Tabasco Injected!
Nov 4, 2010
1,154
Lake Charles, la
Aw Cindy you guys don't worry about my issue right now!!! Enjoy Christmas time as we are, my shop is closed until Jan 3rd! Everyone have a great Christmas and thank you for the response. I can simply copy and paste :)
bluessmax
Tabasco Injected!
Nov 4, 2010
1,154
Lake Charles, la
Letting everyone know, I sent the files to Andrew and they worked fine with him..I installed and reinstalled the latest build of Efilive and now it works...not sure what the deal was but it works now! Thanks
