Help: Truck stuck in 4 low help
BUST'EM 504
1,047
I was pulling a log by my hunting camp today in 4 wheel low. I tried to switch it back in neutral all of a sudden it started grinding bad would not go into 2 wheel drive. I turned off the truck and tried again still was grinding and not switching. No codes everything else is in check.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Were you beating on it? I have been stuck in 4 low before in my 03 gasser I had but it was from runnin the hell out of it and I think it must jam somthin inside and it's a bitch to get it out, that why I just neutral out the transfer and try to restart
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Some trucks are just a :witch: to get out of 4wd low. Blue is one of them.
BUST'EM 504
1,047
no not at all truck hardly ever sees 4 wheel low I just need some low end to pull this log about 15 feet it went in fine just wouldnt come out
Did you ever figure out the problem in the gasser
ripmf666
15,123
14
47
Wentzville Mo
If you read Gm tells you to put the truck in N first and the parking brake then switch to and from 4 low. That stopped it from acting up on me.
BUST'EM 504
1,047
^^^ Thanks im gonna give it a try not that I use it all that often but would still like to know why it does this
Colt
Jul 23, 2010
523
When mine was new it seemed like it would bind up from lots of shaft/gear tensions and it turned out putting it in Reverse just a few feet and D a few times pulling the shifter to find the release pt. I took it out one weekend and did like 60 miles of log roads in 4lo and that thing shifts like a dream now. I'm always afraid of breaking the linkage jerking on the shifter when it's bound up real tight, seen that from another deal.....
