FPE Forged LLY Does 927/1527 Single 3.0 Turbo Fuel Only
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Do you drag race F1 cars? Do you road race top fuel cars? No.. You don't.
It's a sled pulling engine. It only needs to make that power for 30 seconds or so. BTW it has been doing it all season.
If you want 1000hp for 2 minutes continuous buy an Allison 250 turbine engine ;) and talk about it somewhere else.. I'm in the dyno forum dude:thumb:
Wow, Now that is cool, an all season 900 hp motor :thumb: Thats a feat! So if we do the math, if you did at least 3 sled pulls this season you sustained that hp for more than 2 minutes, good job!
"Do you drag race F1 cars? Do you road race top fuel cars? No.. You don't."
I'm sure somewhere in the south they do.........
duramini2001
On a Time Out
Sep 30, 2006
639
Highland, Ut
More interested in longevity, take it to 927 for 2 minutes, tear it apart (if its still together) then impress us with some info, that would be really cool! When did the dyno racing season start anyway.......:thumb:
WTF is wrong with you, 2 minutes??? do you even have a clue what your even saying??? you jump on a dyno forum and try to derail it like a f****** goon, take your S*** elsewhere
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
Nice numbers!
What RPM did it make peak power? Im assuming this is one of your high compression motors with torque numbers its making?
attachment.php
Brayden
Jan 16, 2008
1,170
It was over 750hp from 2750 to 4000 rpm... Torque was over 1000lb/ft from 2250 - 4000rpm :D
If I had the tuning dialed in a little more and used a MAF on it I could get it to come on a little sooner and build torque down lower. That's a 1.10 housing there, a .90 would've had a lot wider power band and more torque but the hp probably would've been lower. I'm going to get the turbine hp up with a bigger turbine and see what happens.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
41
Locust, NC
You gonna go to a 92 or 96 turbine? Have you ever done any testing with the 1.25ar on the 87 turbine?
Brayden
Jan 16, 2008
1,170
Yes we tried the 1.25 A/R on the 87 and with 4.56 gears and 33's it was a pain to bring it up (HOLD IT BACK) on the line. We're going to run the 96 in a 1.0 or 1.10. With 4.56 and 35's it would've been easier to hold, or 4.10 gears.
duramini2001
On a Time Out
Sep 30, 2006
639
Highland, Ut
What was the decision behind using stock pumps? Is it a requirement in the class? Will to give any EGT #'s?
K so I'm a tad confused, you come on with your ignorant statment toward brayden, not having a clue what your talking about??? Then you post up and ask a question to him, how new are you too this duramax game, have you or that squirl under your hood made more than 400 horse?? :rolleyes:
Josh2002cc
That Uncle
Apr 2, 2007
1,832
41
Fishing for free parts or something? :rolleyes:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
"RKTMech" is Robert, Pat and Kat's mechanic , who has done the major wrenching on Casper for years, and is a full time GM heavy line tech aka Duramax specialist ;)
