Just finished building the trac bars... did the drop shackles a month or two back. Everything seems to be working real nicely! Fair amount of work but I have a total of $56 in the trac bars and $0 in the shackles
3/4 heim joints (higher quality of the ones they offered)
I machined up some nylon I had to make the rear joints. (used the same size pipe... 2.5" wide with nylon inside)
Wasn't orginally going to weld to the frame, but in the area where I welded, the frame is already boxed and welded, and I used some wire my dad recommended that may work out better on the frame. I cut the plates in a diamond shape and welded them to the frame first, then welded my mounts to those.
Shackles are at a 3" drop
Just thought I'd share!!
Take care guys,
Todd
Take care guys,
Todd
