LB7: Fpr
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
What type of issues other than an erratic idle could a bad FPR cause? Is it possible it could cause a severe drop in rail pressure?
Maybe , but usually not the case, current hold it shut so usually when they start going bad rail pressure will be higher than you are commanding . the only way it could make rail drop is if the slide was sticking , one way to check is unplug it while logging and see what the rail pressure goes too , it should max out when unplugged.
Gmclbz
Jul 8, 2008
1,048
www.upstatedieselperformance.com
Thanks Trent!:thumb:
onebadduramax
One Bad Duramax
Jul 28, 2009
30
ewwww I hate replacing them.
I think I fixed mine today knock on wood, I checked the wire to FPR , they where chafed , so I bought a new connector, so far so good , but I need to drive it more. To see if my problem comes back. No More tow trucks please
