heater core?
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
i have been having issues with my truck overheating and can't yet figure out y. i noticed this morning on my way to work i turned the heater on to warm it up a bit. on high it would blow hot for about 30 seconds then blow cold. if i turn it to low it would stay warm. i dont understand this sh!t
13,862
966
Does anyone have a pic of how the t-stats sit in the housing? Are they both the same t-stat?
No, they are not both the same. I don't have a picture, but the spring part goes on the bottom.
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
no, they are not both the same. I don't have a picture, but the spring part goes on the bottom.
thats what i thought and i know the one closest the the front of the truck is right but i dont know about the rear. I guess im gonna have to pull that housing to have a looksee.
Darius6t9
I'm the Floater. Lurking.
Aug 23, 2008
574
Rusk, Tx. Again
Put them in a pot of water with a thermometer and bring to a boil. Check what temp they open at on thermometer. Doing it with a torch could verywell have gotten rid of whatever was keeping it closed. Torches get HOT!!!!:D
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
HEATER CORE IS CLEAR!:mad: BLOCK TEST IS NEXT I GUESS! IF ITS NOT HEAD GASKET THEN ITS GOTTA BE THE WATER PUMP! AND IF THATS THE CASE THEN I CAN DEAL WITH THAT AS LONG AS IT STAYS BELOW 82 DEGREES OUTSIDE
maxaholic
1,876
41
Central, Texas
If your hose is hard from driving then you might have a blown headgasket. Pull your glow pliugs and look for any signs of coolant in the cylinder. Or sweet smelling smoke out the exhaust.
REDHOSS02
hard n heavy
Jan 14, 2009
280
F U im from TEXAS
Now heres a little more info....right after the rebuild it was hydrolocking after the engine was shut off and sat for a couple hours. And he found two bolts that bolt the intake manifold to the head, and they are located in the intake y bridge. He said those bolts go through a water jacket and several guys on here said bull shit. So anyways he pulled those bolts and pipe doped them and now its not hydrolocking. But before he sealed those bolts it wasnt overheating!
