if i am not mistaken trent the 71.5 wheel is the same as a Ak5. i would think that at the 725 +/- that the 71.5 is probably at the end of its map. that why i will have a bigger one
if i am not mistaken trent the 71.5 wheel is the same as a Ak5. i would think that at the 725 +/- that the 71.5 is probably at the end of its map. that why i will have a bigger one![]()
kevin,
brayden and dan for that matter are not just buying 4094 wheels or 4088 wheels. or what ever the corresponding wheel for the size and putting them in the turbo. they are using custom wheels. with completely different blade designs. so while the rules state stock appearing. if they cant see parts in side then you can put what ever you want inside the turbo as long as when they tech the turbo it appears stock
I understand the factory housing part. Let me refrase the question:
Is a cheetah 64 a 2.5 inducer, if so what is the AR and trim
Is a cheetah 68 a 2.7 inducer, if so what is the AR and trim
Is a cheetah 71.5 a 2.8 inducer, if so what is the AR and trim
And I don't think Dan is making them...... I think he just bought them ALL from garrett.And at not a bad price I may add.
well i can tell you that i have lower egt's compared to the same tune with stock turbo. we did a comparison when we did my install to see what kind of egt drop i would get. i saw about a 200* to 300* drop
When I installed my 8" turbo back exhaust I noticed a similar drop in EGTs'.
LOL whatever you say
What do you know you are from California, the home of the hippie and liberal freak![]()
Do you really want to start this?
Paint's no liberal![]()
This is why my next turbo from Fleece (which is almost done) will have a whole front end from a GT4202 - compressor wheel and housing and all. I don't want something that is machined to fit, I want something that is made and engineered to fit each other.
I wish and hope that Garrett continues to make bigger AVNT chargers and gets away from "stock appearing". I would love to see a variable GT42 straight from Garrett. I am also very interested in how the variable 4094 is going to stack up to the 68 and 71.5mm turbos from Danville and Fleece.
