ya i forgot to mention head studs are on to do list
just checked my balance rates and cylinder 5 and 6 were at 6.98 when all others were at -.02 or darn close. these are the max numbers.
anything else to check with efi before doing compression check? cant do that today will have to wait to tomorrow
im expecting the worst. i just hope i don't have to do a block
did you put it all together yourself then too ripmf666?
Greg, NelsonDiesel has a complete LMM for $3600 I saw posted on the dp.com. It was initially tagged as an LBZ, but it's actually an LMM. Might want to give him a ring. http://www.dieselplace.com/forum/showthread.php?t=305406
Yea your not going to get much for 3k.rods and pistons will run you around 4950 area, Then the machine shop for cleaning and tq plate honing, and thats hoping you did not hurt the block and can say stb.A cam alone will cost you 900 and your looking at 580 for head studs.and to have everything balanced is anywere from 200 to 700.Gaskets and seals will run you 200 to 500 bucks,I have around 8,500.00 in my motor thats taking off the twins cp3's and the injectors.
I know how it is if your not in the place to do a build. A motor worked for my needs at the time and is giving me time to build the budget for my build and keep the truck driving. Let me know if you need help with anything.
Chad
shit. i hope i don't have to do rods. i only hope i have to do pistons and studs and machine work. any more and i don't know what ill do. id hate to go backwards and run less power after all ive put into my truck so far.
grrrr..... frustration.... damn sketchy economy.
put a call into so cal diesel but sadly guy was sick. so mabye tomorrow ill get to talk to him.
talked to guy today. he said there is a good chance i could have hurt the block. if thats the case i gotta go with 20 over pistons. so now that im back on planet earth i realize im going to be into this for 5K ish.
rods are way out of the question cuz then im at 8K pretty much. would love to, but thats the cut off point for me. any more than 5K and i gotta look into a used motor. who knows mabye ill have to get a used motor anyways if i hurt the rods too. won't know till i tear into it which wont be probably till the weekend after next cuz ill be inbetween jobs and have a week or two off, so that will be a good time to hammer it out.
