started a new thread for easier reference . installed my QA1 front shocks last night and so far the part # DTC1538P worked perfectly , leangth was perfect . Only thing that needs to be done is the metal bushing sleeve is to small for our lower shock bolt . I stole the metal sleave from the stock shocks and used it but you can buy a sleave before hand now that we know its needed . you have to enlarge the hole in the poly bushing to fit the larger sleave i used a drill bit . the top mount is a little loose till you tighten the nut on the shaft compressing the bushings and then it is very solid no play .
so far quick drive last night and they are very very nice , but they should be for that price , i ended up for stiff street/performance set up 10 clicks rebound and 5 clicks compression , there are 24 clicks for each setting so there is plenty of adjustment for our trucks . i will keep updating this thread as testing continues. As of this point i can say they seem to be worth every penny
front end dive under breaking is non exsistant, and cant feel any lift under exceleration but ride is not harsh stiff wich i like but not harsh . i will have them at the strip in 2 weeks
