Is it for perfromance reasons that people lower their trucks or is it just for looks? Im thinking about dropping my rear 2". Is it worth it?
Would i even notice a 2" drop? Driving wise?
No you won't
If you lower and add bags like I did, your ride will suffer greatly. I have talked to Pac Brake and they suggest to get a single sleeve bag, that way you will get a little more axle movement. If you order a PacBrake bag kit, and specify a single sleeve bag instead of convoluted, they will exchange it at no additional charge. Same weight carrying capacity. They did this for me for a customer of mine after I told them about my ride quality.
are you going to do this on yours chad ?
How are shackles changing your ride quality? You have the same weight on the same springs. This isn't the first truck I've put longer shackles on (some to lift and some to lower) and the ride quality was never compromised. The lifted ones were more top-heavy and didn't corner as well and the lowered ones cornered better. Traction bars preloaded will make the back ride rough.
I said myself that the spring rate doesn't change. The spring has less capacity to rebound. Which at the same spring rate with less travel means what? Stiffer spring. I'll dig up some info in books I have for you guys
