Hello all, I’m having g some trouble finding information on head gasket selection here in the forum. I’m new so that is probably the reason. At any rate, I wanted to ask a few questions about my piston to deck clearance and hopefully discuss the methods of checking said clearance. Also looking for info on head gasket selection based on these clearances. Ok, so I just got done checking my LLY block. It has Mahle cast race pistons with .075 pockets. The way I was taught on gas motors was to check the bottom and top crown areas while rocking the piston. Add the top to the bottom and decide by two. That would give the average potential for piston protrusion. That said, I have also heard of using a strait edge and feeler gages as well as simply using a drop indicator in one location on the piston. Which way would you guys lean towards being the most solid way of testing this?
On the subject of head gaskets based on the clearance I have just measured. Bank 1 top number was .0175 on cylinder #7 and Bank 2 top number was .0155 on cylinder #8. This would lead me to believe and correct me if I’m wrong on any of this. That a grade C Mahle wavestopper which measures 1.05mm or .0435 would allow a little more than .020 thou clearance on both banks which would be plenty. I’m not 100% sure what GMs spec is on this so if anyone knows, please share with me.
Well that about sums up what I’m looking to discuss and the questions I have. Feel free to comment and weigh in on any aspect of the task at hand and as always I greatly appreciate all of you. Thanks
