Does anyone have a part number for an S&B filter that is a replacement filter for the old WCFab intake filter?
I was running an AFE Prodry on mine, tried to get the largest one possible but at the time their options were limited. Ended up with a PowerDriven filter, R2C was making them but I thought R2C went under? Either way I've had great luck with mineIn my opinion, the best bet is measuring what filter will fit and buying one accordingly.
I've seen the best performance out of Power Driven Diesel's filters (dry) as well as AFE Pro Dry S filters. Meaning least amount of dust in the intake and the lowest restrictions.
Yeah I run the power driven diesel filter on my truck. Its a 5x12 performer, the dustbowl version is for applications that will see dirtier driving conditionsIn my opinion, the best bet is measuring what filter will fit and buying one accordingly.
Like Ike said, measure how much room you have and run biggest possible.It’d be great to measure the filter I have if I had one…
Anyway, I think the correct S&B replacement is CR-40035D. It looks pretty similar.
@DuramaxRamRod This is not the intake with the box.
If you can fit a larger one, it's worth the effort. Measure the diameter of the intake pipe and filter the results on the filter company websites. See what's available and measure for clearance to decide.
I 3rd this. It's worth the effort.Like Ike said, measure how much room you have and run biggest possible.
I'd have to measure what I ended up buying (I'm guessing the 6x11) but it's big enough that I have to put the filter in the air box and THEN feed the intake tube down into it
I bought an older WCFab intake in a bundle of stuff.I have a brand new S&B kit for an LBZ if your interested ...
