Mini max controller
Supermoto68
30
I have a problem that has been going on for long time, my truck has traction control but. No switch to turn it off. I have the mini max controller, but no one has updates for these. Has anyone else had this issue
ZeroGravity58
1,427
56
Maryland
Pull the fuses for the abs. I had th same problem. My truck has stabilitrac and even with it off it would pull power. At the track I would launch and the truck would fall flat on its face. Pulled all the ABS fuses. I pulled my cluster and took out the bulbs so it's not shining like a Christmas tree
Supermoto68
30
Really , looking for long term fix. I am not racing the truck. I pull RV and going uphill on wet, icy, muddy road, pulls out power and I cannot move.
4,846
1,894
There isn’t a medium to do what you’re asking other than pilling the fuses. I have yet to see any form of tuning that can 100% kill it.
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
I’ve never had a problem with it pulling power on an LMM with traction control and stability control disabled. Now on LML it does turn back on after 45mph(something like that can’t remember the exact mph)even if it still shows it’s disabled
pl_silverado
199
180
Even on the 2009 & 2010 models with JL4 RPO?
Ive ran the same tune on 2007-2008 trucks and 2009-2010 trucks, and the older ones absolutely rip, feels like the newer ones are holding back. Never figured out why.
ZeroGravity58
1,427
56
Maryland
I tried everything with my JL4 and nothing worked but pulling the fuses. There Is no other way to disable it and leave the fuses in that I could find. Even with it off at the drag strip it still pulled power right at launch it if would spin my.
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
Yea never had an issue. I have an 08 and my friend has a 10 with the JL4 and they run identical both hold 120mm3 entire way down the track.
