Raising LMM compression
WVRigrat05
3,146
French Creek, West Virginia
I bumped the compression up in the LMM to 17.5:1 and it’s like a free 50 horse, also I’ve burnt a half tank of fuel in 100 miles. What needs adjusted in the tuning so I know for my knowledge so it’s not back in the garage next week.
Yngdmax92
962
Not tuning related, but how did you bump compression? What pistons did you use? And did you change the rods?
Sent from my Pixel 2 using Tapatalk
Yngdmax92
962
pistons...
Okay..... Lol. Maybe I should of been more specific as I'm interested in what he used to rebuild this engine as I know he's not too awfully nice on things and like watching the longevity of the build. So.
Did you use lb7/lly pistons with a thinner gasket?
Or an actual aftermarket piston for the achieved 17.5 ratio?
1,514
Increase CR is free HP increase, throttle response will go up as well
Usually playing with timing map to get the most out of it... If it's sharp rattling need to pull timing.. usually 2-3° will make it stop..
I've found more adjustment was need in part throttle area vs WOT
WVRigrat05
3,146
Mines just snappy around 2200 and drinks fuel, a lot of it. Definitely runs better, it’ll blow the tires off over half throttle on tune 3, don’t like that.
And no rattle, it’s quieter than it was before, just likes fuel and at 2200 rpms it’s like a power band on a dirt bike, something needs cut back for sure.
1,514
What's tune 3 supposed to be at the re tires... If you picked up ~"50hp" on base tune it will be more on the higher tunes
Maybe you're not used to the extra HP and need to recalibrate your right foot?:rofl:
Fingers
Village Idiot
1,735
142
White Oak, PA
I seriously doubt it bumped your HP much. It will change the character of your engine's response.
At 17.5 :1 , Mine runs like a raped ape above 2200. Loves to spin. Pulls hard all the way to the 4500 limiter.
But, if I ever have cause to do it over again, I'll go with 16.5 : 1.
WVRigrat05
3,146
No, I know it didn’t, but it’s very responsive, gonna have to make some changes so the throttle isn’t so touchy, I’m curious how much I need to lower the timing now to keep things happier.
Fingers
Village Idiot
1,735
142
White Oak, PA
Several personal reasons for wanting lower CR. I've had the chance to compare them side by side.
First, and most important to me, the lower CR engines are much quieter and smoother power.
The "bump" in response at 2200 is a pain in the butt with the higher CR engine. I've tuned most of it out, but it has been a struggle. I think the cam is playing a role here on my engine, but have seen the same thing on stock cam engines with higher CR.
I personally have not seen any increase in MPG. Actually the opposite. That is comparing ovals to ovals. But the pistons were not the only mod. So the comparison is not worth much.
I don't think the ring package on the Duramax is up to the task of higher CR. I have not looked into it much other than some chamber pressure observations. Whereas a 16.5 CR piston would show an effective 16.4-16.5 ratio on the pressure graphs, The 17:5 pistons would be more like 17.3-17.4 effective CR. I attribute the drop in effective CR to blow by and have not chased it beyond that.
Lastly, a Higher CR is harder on parts. A jump from 16.5 to 17.5 is about 7% more strain on all the parts just in increased pressure at any load.
Just my opinions. Each to their own. When customers ask, I recommend 16.5 for a Daily Driver, 16.0 if you are running a lot of boost such as with twins.
WVRigrat05
3,146
Slapped a set of LLY pistons in, grade C gaskets set valve lash at a tight .011 and let er eat on the 120 tune. Just changed the oil filter with 200 miles on it and it looks like strippers have been dancing in the motor, I’ll change the oil and filter at 500 miles and see what it looks like. Motor hasn’t been over 2500 rpm yet.
1,514
Depends on what's ones end goal..
All out 4 digit HP probably not ideal.
I know Dan's diesel ran a set of ~19:1 ovals..
I know couple guys that ran 20:1 in the Cummins.
Personally I'd like to have a set of 19:1 in a 6-6-650hp truck
One of the benefits of higher CR is more responsive to throttle inputs are low-mid throttle
N2BRK
2,393
733
So you're saying - build a truck to handle higher stress at lower RPM vs stock and then limit it to 6-650hp so that it's super responsive with more CR and less boost. Hmm. Sounds like a hell of a balancing act, but it makes sense that if it's DD reliable, perhaps an explosively responsive 650hp would be more street fun than a 900hp typical street truck. I dunno. I picture it as a tire melter and maybe not as nice to drive DD... guess you'll have to build one and let me borrow it for a few years :) :) :) haha
