My Step Father has a 2001 Sierra with the 8.1/Allison that has only like 80k on it, lived in a garage most of its life with trips to Vermont and Florida mostly. A few years ago, IIRC, it started throwing a crankshaft sensor code, and I replaced the sensor for him. Everything had been fine since then until probably three or four years ago. It started doing a crank no start, followed by starting no problem. On first attempt, you could hold it on start for however long you want, and it'll just crank, but if you return the key to run and then immediately try to start it, it fires right up like normal.
It's had me scratching my head because there are not DTCs and nothing has stood out. I know the fuel pump has been replaced, but I'm not sure offhand if anything else has been replaced.
Does anyone have any ideas? It's so odd that it's not just a long crank, it simply won't start on the first crank, but will just start like nothing on the second attempt, and there are no codes like crank or cam sensor issues.
