Did a search on the forum and couldnt really find what I was looking for.
2002 3500 DRW.
New to me truck. Found a ton of power steering fluid under the booster and the PS pump. No whine from steering when I got it. Little bit of a moan when applying brakes.
I decided to replace the PS pump with a reman from autozone. Currently waiting on the new booster.
Bled the system. Turned the dang wheel and pressed the brakes for an hour and a half, engine off, front jacked up. No bubbles. Fluid wasn’t dropping. I could hear gurgling when getting to the steering lock but figured it was just the return line spitting fluid back into the reservoir.
Cranked the truck on. Pressed the brakes and could immediately hear the PS pump whining. Then whining with steering. The brakes work fine and the steering feels normal. Just the loud whine.
Bad steering pump? They only had a trugrade in stock so I bought that. Not strong enough? At a loss right now.
2002 3500 DRW.
