My "New" 2016 Canyon
Lennydmaxguy
Just another diesel tech
Nov 8, 2023
125
65
Somewhere, USA :)
What type of Boost numbers are you seeing?
I'm trying to keep it around 32 PSI max. It would easily make more if I asked for it though. I found a chart that shows the max safe boost for all the Stealth lineup, and they rate this one at 36 PSI at sea level. I replaced my MAP sensor with a 4 BAR sensor, but I'm having a hard time finding scaling information for it. I want to make sure I'm reading the correct number before I push the turbo harder.
Lennydmaxguy
Nov 8, 2023
125
65
Somewhere, USA :)
What tuning did you have to do in order to use that DT44?
I actually changed very few things over what I was running before. The biggest thing has been the MAP sensor, as I explained above. Calibrated Power says on the sheet the comes with the turbo that they will review data logs for free to make sure their turbo is working right. I sent 2 logs, but no response from them in 4 days. IDK if they don't do that anymore, or they're just busy.
