VGT 68mm 9 Blade?
Ironhide6.6
May 21, 2025
14
Ontario
So ive never heard anything good about the 64mm 9 blade, that they arent reliable at all. Now ive been doing some reading up on the 68mm to still make some good power with twins in the future but i also read that it can come in a 9 Blade. I wanting to know if its just the 9 Blade in general that is unreliable or is it just with the 64mm?
So i want yalls opinion on if even though they are obnoxious are they more reliable with a bigger turbo?
4,846
1,894
The 9 blade is 100% the problem.
What are your HP goals and usages? You can go to something like a JZ Mfg 4094 based 68/68 with like a 485 or 488 over top of it in compounds. That setup is proven to 1000-1200whp on various trucks and still has pretty damn good street manners with proper fueling/converter/tuning.
Ironhide6.6
May 21, 2025
14
Ontario
Oh ok, I’m wanting to get to that 1000hp mark sometime in the future. I was wanting to do the s467 over the s488 but at the same time that’s like the goal in the next 3 years. In the meantime though I want something where the whistle is strong and so is the spool up. I’ve already made the decision on the 67 and 88 for that 3 year mark but like I said I just want something to f around with that has that loud whistle ig
4,846
1,894
What HP goal do you want for the truck now? If you want good performance (quick spool up) and that whistle sound a JZ Mfg 63.5/66, Fleece Cheetah, or Duramax Tuner Mach 1 are all great choices
Ironhide6.6
May 21, 2025
14
Ontario
I was thinking something that won’t blow up if I get the 88 first so like the 800 mark.
Ok sweet thank you I’ll start looking into those
Ironhide6.6
May 21, 2025
14
Ontario
Ok thank you, do you think it would with hold 900 or is 8 the farthest I want to push it. Just incase I get my fuel dialled
4,846
1,894
I have pushed a 63.5/66 with a 480/96/1.32 over to comfortably to 775-825whp based on track times. Everything "seemed" happy looking at overall boost and drive pressures. I don't see why it couldn't make 850-900whp with a 488 feeding it.
