Drivers Door Pwr Window Switch Issues
Rickyb013
Jun 21, 2020
My 2018 Silverado LTZ sat for 3 weeks and when I started it the only switch still working on the Drivers door is the Drivers Window and Power Door Lock. The Mirror controls and all 3 other Windows no longer function. All windows work fine from their own door switches. A couple of questions
1. I've heard these switches may be sensitive to Low Voltage and can lose programming. (The truck did roll over a little slower than normal) Is this factual ?
2. I've had no issues ever with this Switch Assembly and it just stopped working correctly. Does this sound like a failure that may be fixed with Reprogramming ? and
3. Is there a way of an owner reprogramming/re-configuring the switch, or is this something a Dealer MUST do ? Somebody must have a work-around ?
Thanks in advance for any help,
cdbright
JUST RENT IT
Dec 16, 2008
1,016
Salt Lake City, UT
I currently have this issue on my 16 , i get the "roll up thrn roll down drivers window" code, i am pretty sure i have a split in the wiring harness in the door whee it bends every time open/close. Gine tear into harness tnt and re tape it all and should fix issue, also read the motor can cause this code to be thrown but i can open door to the right spot and i get window again so i think i have a split
SoCalMike
851
79
California
Have you tried to charge the battery? Also, I had a similar problem with my LBZ seat. One of the seat functions would not work for some reason. I disconnected the batteries for a couple minutes, reconnected them and everything work again. you might give this is a try after you charge the battery.
cdbright
JUST RENT IT
Dec 16, 2008
1,016
Salt Lake City, UT
I changed both batteries a couple weeks ago , then it came on about a week after that , i did do one batt at a time so i wouldn't lose my presets on my radio so it never really did reset
3,422
Broken wire between body and door or bad connection within door harness connector just inside body cavity would be my assumptions.
