No ecm tcm or gpcm
technodude000
Oct 28, 2024
Alaska
Hey so been at this awhile. The gmlan bus is fine and if I unplug the tcm and jump the gmlan bus the whole system comes online. But as soon as I put the tcm back in can't see tcm pcm or ecm. Tried unplugging trans. Has all required powers and grounds. Any ideas I'm at a brick wall
8,050
Need to make model year and what code you have but if you’re losing all GMlan with the TCM plugged in, but it comes back after you unplug the TCM and jump the wires, indicates the TCM has an internal problem
technodude000
Oct 28, 2024
Alaska
Even with a brand new one
2012 2500hd with 6.6 duramax
8,050
What’s the ohm reading on the + and - of the canbus line measured at the OBD2 port with the tcm hooked up?
technodude000
Oct 28, 2024
Alaska
So new development. Hooked just the tcm powers and cam bus wires up and can see everything but tcm still can't be seen. But that's only like this
