October '23 Chat -- "Spooky Times"
8,237
But the real question is what will can we get out of a stock turbo before we need to upgrade???
Lol my money is on the engine going first if you want to keep it 91/93 tuned. If you go e85, might be able to max out the turbo but your biggest issue will be ring gap. You won’t have enough, unless the engine is worn, to max out the turbo
3,589
Comp ratios between the two engines, LCV - 11.3:1, LTG - 9.5:1
LCV has piston oil squirters, too. Couldnt find specs on ring gaps.
