New or Re-Build Steering Box
5,101
703
Where is your leaking? Mine was leaking by the steering shaft. Put a new seal in it since it was still tight and it's been good. I didn't even do all the seals on that side just the easy one and it's held so far.
OleBlackyLBZ
353
86
I need to take a closer look but from just a glance it seems to be coming out around the shaft on the bottom. My box is still good and tight though...
3,590
If the seal kit is easy to find and not expensive, that would be the first direction I would go. Nothing to lose by trying to fix what you already have.
8,237
the sector shaft seal means you need to do a complete tear down to replace it (thats the seal you think is leaking). the hardest part of that process is gettin all the balls back in the case and not letting the worn gear travel so far you cant finish putting them in. its not hard, just a little finicky. use vasoline to hold the balls in place at the end.
Make sure you mark the bearing nut that holds preload on the input shaft bearing so you dont overtorque it, good way to kill the box (did that years ago on my original). beyond that, its just messy.
OleBlackyLBZ
353
86
So I decided to just replace the whole steering gear with a blue top unit, I absolutely love it! I had no idea the steering could be this tight on an obs truck. I was not impressed with the customer service at all but the box seems excellent, I have around 1,500 miles on it so far.
Is anyone getting good mileage out of any of the remans like PSC or blue top?
4,850
1,901
One of my customers has ~45k on his PSC box and it's still as tight as day 1. I've never had good luck with Red Top/Blue Top reman boxes holding up long term but that is my experience, I know many people have had good luck with them.
Just curious how you sourced this Josh. When I ran the number at rockauto below was the fitment. In fact, they don’t even list any ac delco for the classic trucks
CHEVROLETSUBURBAN2016-2017
CHEVROLETSUBURBAN 3500 HD2018-2019
84400715 bought this from Rock Auto for $290ish last month and installed it on an 08 dually.
Options on Rockauto were cardone Edelman lares and BBB. Anyone have experience with any of these either rebuilt or new?
Edit: just stumbled across this thread that answered a lot of questions. https://www.duramaxdiesels.com/forum/threads/01-10-steering-box-redhead-psc-oem.82567/
Gonna try the BBB I think.
Installed a PSC XD in buddies ’03 the other day. Bit of a bitch. Came with an aluminum adapter fitting for the one hose for some reason. Turfed that right away as it wasn’t going to fit.
Also had to bend the one steering hose 90 degrees off the fitting so it would clear the hot pipe. Not a fan of the $1150 CAN price tag either. Steers nice though.
4,850
1,901
IMO there isn't a better steering setup available for these trucks than the PSC box/pump combo.
