LMM Swap into LLY Truck
79LT1Monte
Apr 18, 2022
Looking for the best way to swap my LMM into my 2004 LLY truck. I have everything from the LMM donor swapped into a 1998 truck now and I'm just not happy with the truck itself being kind of Frankenstein and I want to redo it cleaner into this 2004. I want all of the gauges to work, ABS, cruise control, etc with no warning lights or messages. My question is are people re pinning the 2004 BCM with the serial data wires from the LMM PCM and TCM to make it all talk or are you some how running both BCM's in the truck? Again I want everything to work and look factory like DuraBurb and companies like that are doing. Thanks in advance.
Cougar281
1,755
214
St Louis, MO
Can't do it. LMM modules talk different languages from the LLY modules. Only way to do something along the lines of what you're talking about is ditch the LMM harnesses, find LBZ harnesses and ECM, TCM and GPCM. Those would be able to communicate with the rest of the trucks modules. Or a total interior swap, if a GMT900 interior could be bolted into a GMT800 truck.
4,955
Pretty much this. interior swap isnt a bolt in, it will need alot of fab work to get it all to fit
the good part is the LMM is basically a LBZ so you just need the harnesses and computers. if you have a early LMM with the a40 tcm, i think you can keep that and just flash a LBZ os in it. might even be able to do that with an a50. if its the newer t13 or what ever it is, not sure on that but i think its still possible.
