Drag tires
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Hey guys, looking for some advice and recommendations on drag tires for the lb7. I need new tires before this season gonna hit the track again
ZeroGravity58
1,427
56
Maryland
I know alot of people run 30x14 cheater slicks or Toyo proxies or Nitto 420's. One tire that has impressed me on other cars and trucks is the Nitto 555R2 and Nitto NT05R. I thought about trying a set...
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
I have Mickey thompson ez streets right now but they have seen better days
ZeroGravity58
1,427
56
Maryland
I've never ran a Duramax with slicks on all 4 corners, just nitto 420's . I've Drag raced plenty of other cars and trucks and I always preferred to stick the radials over biasply. Radials are more stable and easier to handle
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,768
545
P.N.W
Dont you run them on PYO's? If so what size. I know the pyos are one of the lightest wheels just sucks they are 6.5" wide
No I run them on 16×10 -25 offset 4.5 backspacing bogart race wheels with beadlocks.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Current setup
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
Need something to hook at the track the set up I have worked great when I was 600hp and not so much at 1100
Is your locker in the rear working? Rear end rising on launch? Front end not hitting the bump stop? I run street tires launching on nitrous at 1000hp and can get 1.5 60’s all day
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Back stays put the front tends to lift
I have a 3/5 drop on the truck with qa1 shocks
8,237
Need to make the back end start working for you.
how much toe out in the front end are you running? (if any at all)
how much room do you have between the upper control arm and current tire/whee setup? the more back space you can run, the less leverage the tire has on the steering and the more contact patch you keep on the track from less toe in. hence why guys run toe out
