its time...
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Hey all. Ive been busy! I found a core long block. I have it completely torn down. its time to start figuring out exactly what I should do with it. I was hoping the cylinders would clean up and not require any boring, but the engine sat long enough there is some slight pitting in one cylinder from moisture, so I dont think I can get away from boring it over. From some random measurements I took the bores were all from 4.0555 to 4.0565. I am on a budget with this build. I originally thought id shoot for a 800 hp capable engine, but that seems out of reach for me. I am now wanting to do a reliable engine to handle what I have now. I would say 600-700 for you sea level guys, but for me at 4500 ft its probably in the high 500's to mid 600. Here is a list of what I have come up with so far.
Mahle motorsport pistons + .020
lbz rods
Mahle H main and rod bearings
Mahle head gaskets
Head studs arp? not sure.
some sort of valve spring kit. socal?
Have the machine shop prep the block for whatever it needs
balanced rotating assembly
key the crank and cam
have both heads serviced
get the crank checked out and polished. There are some scratches in it. I hope its usable. (see picture)
60% injector nozzles
a couple things im wondering. Do I need pushrods? or are the stock ones ok?
can I use the core engine or my old engine oil pump and tear it down, check it over, and key it and shim it myself? or do i need to spend that 400 on a new one?
also, whats the deal with the welded water pump. Is that really necessary? I could also do that, but Im unsure about the need for that.
90% of the driving with this truck is on level 3 of my dsp. its not a race truck or a sled puller. I tow with it most of the time, and do the occasional sprinted street run. Id love to do some billet rods, but I don't think the extra 1700 is in the budget for them. maybe if I found a used set.
any recommendations on things I should do, or would be a good idea are appreciated!
attached a picture of my redneck engine stand haha. and the pitting in the cylinder.
3,906
1,074
Neenah, Wisconsin
lbz rods
Mahle head gaskets
Studs: You need new head fasteners either way. Xotic is ~$90 more than TTY bolts and ARP is a couple hundred over bolts. Personally I'd go studs but this is a personal decision since the factory style TTY fastener will be just fine.
Springs: I use XDP/Manton or SoCal, hard to go wrong with either. The nice part with the XDP/Manton come with new locks incase one of yours decides to fly across the shop.
Pushrods: IMO anytime you increase spring pressure you should do pushrods. The OEM pushrods aren't the best to begin with and for the ~$300-$350 it's not a bad investment. Again, the Manton/XDP or SoCal stuff is my preference here.
Oil Pump: I would personally spend the money on a DHD or Wagler pinned/shimmed LBZ pump. Not only are they new from GM, the drive gear is pinned and they shim the relief to increase operating pressure.
Water Pump: If your water pump isn't very old/in good health then by all means weld it. If you're going to replace the water pump, this is another place where DHD's and Danville's modded pumps are hard to beat. They take a GM LBZ pump and weld the LB7/LLY hose barb to the new cover as well as drill the missing mounting hole in the water pump tab. They also include hardware to replace the front cover stud meaning you won't have to take the balancer off to change water pumps in the future.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
hey thanks. I know you recommended the push rods, but i thought maybe it was power that make them a necessary upgrade. I didnt even think about the valve springs. my water pump is pretty new. why the need for welding them?
3,906
1,074
Neenah, Wisconsin
The water pump impeller has a tendency to spin on the shaft and leave you with zero cooling. It’s common to weld both the cam side and the impeller side as that was the hot ticket until the resin impeller pumps proved to be far more reliable.
3,681
I personally think you could skip the pushrods, especially on a budget. I am running the SoCal beehive valve springs, have spun the motor as high as 4,800 RPM, and am using the stock 350,000 mile LB7 pushrods. I have over 50,000 miles on the built motor so far, and they are just fine.
Maybe I am just lucky, or the cam I use is easier on them than some other cams? But for $300+ savings, I'll risk needing to go back in one day and swap them out. Only should have to pull the valve covers and rockers, so easier than injectors IMO.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thanks guys. Im at the point now where I need to start calling around for engine machine shops that can work on these parts. any thoughts on the crank? doesnt look good to me, but i dont know much about them.
OleBlackyLBZ
350
85
I would spend the money and throw a new oem or callies durastar crank in there and stay stock on the valve springs and pushrods if your staying around 650. Just my opinion
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
yeah... after completely destroying my 85k engine because I overrevved it and floated the valves, I definitely am upgrading valve springs. I found out the hard way it doesnt take 650 hp to float the valves on these trucks.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Brad has me set up with Manton valve spring kit. Parts are at the machine shop now. He's going to try and get to checking everything out next week. Nice guy. Seems knowledgeable. Does the machine work for most of the repair shops in the state of Montana.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
so I just checked the main oil clearances. They seem to be all over the place? what do you guys think?
1- .002
2-.0025
3-.0018
4- .002
5- .002
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
first time was with my dial bore gauge, and a micrometer. so I just did it again with plastigauge. for some reason everything shrunk. They appear to be a bit on the tight side, but its within spec of my Haynes manual? I might try to swap those like you said. Otherwise, I think I'm good. Measuring both ways I'm within spec.
1-.00175
2-.002
3-.0015
4-.00175
5-.00175
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
I am leaning more towards the dial bore gauge measurements. I dont really like the Plastigauge way. I think its a bit hoaky, and I don't like the way the gauge they give me goes from .0015 to .002. Most the them seemed to be bigger or smaller than the gauge.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
ive hit a bit of a road block. I only have .001 end play. Would that be caused by the assy lube holding it up? when I pry with a screw driver, it will go about .005, but settles at .001 when I let go.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
not sure how great an idea it was, but i sanded the thrust bearings with 600 grit until I now have .003 end play all torqued down. It was .0045 before torqueing everything down.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Livingston. he is in Belgrade. I cannot remember the name of the business. I think his stickers say DEMT? His name is Rob. 406-813-9810
