Lb7 high idle.
slowlml
Undercover Epa agent
Feb 6, 2015
577
53
Strasburg Va/Wardensville Wv
Whose kit is everyone running for a high idle on the lb7s, I've looked at the merchant kit and bd. Any other options? Merchant seems simple enough and cheap. I need two of them.
ironmax
chock full of goodies
Jul 7, 2010
502
27
Col. Ohio
Can't the pto provision be turned on with tuning and allow the cruise control to manually raise idle?
slowlml
Feb 6, 2015
577
53
I remember reading something about controlling it with coolant temp years ago but wasnt sure if that works on the lb7s. If you can ill just have my tuner make one of them be high idle. I know you can do that with the merchant kit using a wire from ecm to brake pedal switch.
DuramaxRamRod
171
23
MI
I used a pre pinned wire from BT Diesel when I did mine. Looks like it's no longer offered.
If you can crimp the pin to the wire I would do that otherwise I'd go with Merchant's kit.
