LLY and LBZ/LMM injectors
bobxr50
Been around
Mar 3, 2008
61
mn
Just wanted to confirm info. You can run LBZ LMM injectors in a LLY? Older info in the past states that you cannot. Just wanted to clear it up either way.
3,908
1,074
Neenah, Wisconsin
Opposite. The LLY injector body is straight whereas the 06-10 has a slight taper causing the LBZ/LMM injector to not seat properly in the LLY head.
4,950
If you have a friend with a lathe, .015 off the Lbz/LMM body of the injector resolves this issue.
bobxr50
Been around
Mar 3, 2008
61
mn
Totally understand about the sizing issue. I was wondering about the ECM/FICM. No performance loss with the LBZ injectors vs LLY
4,950
It may take some tuning work to make it run/sound smooth as lly Fire off 48v and lbz Fire off 24v from what i remember. Couldn’t answer longevity. They will run and work though
