https://www.lasleeve.com/downloads/...Automotive-Performance-Industrial-Catalog.pdf
LA already makes a flanged sleeve:thumb:
Not sure I'd go with a half filled block. I had two engines in a row with cylinder cracks and I know at least one other person with similar results. The cracks just happened to be right above and below the fill line (straddling it). YMMV, this is not intended as legal advice, etc :thumb:
Guys still split the hamilton blocks![]()
Shaddey just windowed one last week or so. D&j has one out now that lavon is going to run. Heard the sticker is well north of 60k. They said they have 2800 hrs into making it.
Drew needs to get his shit together on quality control. Hopefully thats all been addressed. 60k should be an entire long block (depending on head options). The ex-race cummins we built has a D&J engine, everything you can throw at it accept the top of line sled pulling head. it was 40k. deck plated stock block. Its made 2200 at the crank and been putting 1700-1800hp to the wheels but the first engine from Drew had the oil squirter for cyl 6 completely aimed the wrong way and we killed cyl 6 after 1/4 mile passes. Second time, killed cyl 6 again and Drew would not let us open it up if we wanted any chance of "warranty" on it. i know things got sour after that and mark/fred wound up shelling out quite a few dollars for another rebuild that was not our fault. Shaddy tunes the truck and Drew wanted to blame tuning. Ben sent Drew logs of each individual clyinder EGT along with all the other complete data, the fact we run 1300uS at 1700rwhp, and so on. We stopped running 1/4 mile (no need since we were still the fastest in the state), keep drive pressure at 1:1.5, had all injectors serviced and checked after the first fail, and went over that truck top to bottom. still continued to blame him. Ben wound up going with Fleece at that point and Brayden has surpassed Drew by a mile. He was fleeces first test mule for their billet block. it wasnt the block that gave up from what im told.
