03' GMC SoCal stroker
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Did a pull last weekend and lost the water pump and got the engine hot. It blew the top radiator hose off. Still managed a 4th out of 35 trucks, it was a diesel shootout class, all diesel pickups compete in the same class, from stock to fully built trucks with Wagler billet motors. Here's a video of pull.
https://youtu.be/C5kKWFuSIUY
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I pulled the motor, heads are going to SoCal to get checked out. Short block looks fine.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I haven’t updated this in a while. I ended damaging both heads when water pump failed. I ended up buying Edelbrock heads and a Wagler billet water pump so hopefully this doesn’t happen again...
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I ported the Edelbrock heads a little
Custom billet CP3 wheel
Cleaned up the fuel feed and return lines
Updated to a FASS 260 pump with Woldfab mounting bracket
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Almost ready to start up.
I updated injectors to 250’s from 150’s.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I also made a C3 Oiler, and no truck doesn’t have a ATS tranny in it...
1,862
Are you worried about fuel volume at all with 3/8" vs the typical 1/2" line or is the image you for the brand? Looking on Amazon they do make a 10an to 2x 8an. Has me thinking about re-plumbing my fuel supply and returns now....... I know the inlet on the pump is obviously smaller than that but I'm wondering if the fuel volume directly at the inlet may help.
