Hey guys So I just replaced my old ac compressor and the manifold line that goes to the condenser and the accumulator, it had a small leak... once I replaced everything I pulled the all the moisture from the system with my vacuum pump for a about 30 mins then I let it sit for a while and it didn’t loose any pressure. So I went ahead and started the truck turned the a/c on max and went ahead to recharge the system with r134a. I’ve seen that the right amount of refrigerant is 1.6lbs but I could only get about 18 oz in the system before the low side pressure gauge read about 38-40 and the high side read 250! I didn’t want to try and put anymore refrigerant in the system because I thought it was getting pretty high on both low and high side. So I decided to turn the truck on and see how the ac feels... I put a temperature thermometer in the vent and it only gets to 70°f, which feels ok in 105°f weather but not good enough. Anyone have any suggestions, I don’t know what else to check!
