in other news, we've been short handed at work so hours have been long and i keep opening the garage hoping someone has magically appeared in there to fix my truck..... it aint happened yet.
I did order up some heli-coil's and key-locking threaded inserts for the bellhousing/converter. im thinking i may make a real quick jig to hold the drill bit straight on the converter so i can drill it and then use a shorter jig to tap straight. i dont know if there is enough meat on the converter or bellhousing for the key-locking inserts but thats what im aiming to use, otherwise the heli-coils and a little JB weld on the outside thread edges will be used. Ive done the helicoil deal in the past with my samurai stuff to strengthen the head stud threads and exhaust manifold studs. Didnt know about the key locking stuff then which is way cooler
